Status modem saya (Linksys AM300):
DSL Status: UP
DSL Modulation Mode: G.992.1 (G.DMT)
DSL Path Mode: INTERLEAVED
Downstream Rate: 2458 Kbps
Upstream Rate: 613 Kbps
Downstream Margin: 31 db
Upstream Margin: -16 db
Downstream Line Attenuation: 6
Upstream Line Attenuation: 0
Downstream Transmit Power: 9
Upstream Transmit Power: 3
LOS Errors: 0
Kenapa ya kok upstream margin selalu minus?
Downstream Upstream
SNR Margin : 22.5 23.0 db
Line Attenuation: 44.0 31.4 db
Data Rate: 448 123 kbps
Max Rate : 4704 164 kbps
Bos, biasanya SNR ane 40 an
Dan LA nya 22, kok, sekarang terbalik ya ...
ada yang tau cara ngebenerinnya?
bagus gak ya ![]()
wAh saMpe mumeT bacanyA...
.. taPi maNTap tambAh iLmu.. ![]()
ijin sedot bapak.
Bagus gak ya Speedyku
Current adsl line status is as the below.
Line Mode ADSL2+ Line State Showtime
Line Up Time 00:04:43:44 System Up Time 00:04:44:08
Line Downstream Rate(kb/s) 3068 Line Upstream Rate(kb/s) 507
Latency Type Interleave Line Coding Trellis On
Noise Margin(dB) 24.9 Line Attenuation(dB) 38.5
Output Power(dBm) 12.3 Attainable Line Rate(kb/s) 8824
Line Up Count 1 Status No Defect
Statistics Downstream Upstream
K 95 16
R 16 16
S 1 8
D 0 0
Super Frames 1052603 1001372
Super Frame Errors 0 1
RS Words 69471830 4267772
RS Correctable Errors 721 0
RS Uncorrectable Errors 0 N/A
HEC Errors 0 0
LCD Errors 0 0
ADSL Port Enabled
Downstream Line Rate 3068
Upstream Line Rate 507
LAN IP Address 192.168.1.1
Ethernet MAC Address 00:25:12:d4:23:e2
Firmware Version ZXDSL 831IIV7.5.3c_Z29_ID
