Topic: [TOLONG] trigger AFTER INSERT buat UPDATE
para abang2 db master pgsql... q minta tolong dong...
niey aq ada permasalahan, q mau buat trigger AFTER INSERT....
jadi kalo aq sdh insert di table rs_karyawan maka akan terinsert di kolom "nik" dengan otomatis, tp aku pingin nomorNya d depanNya aq kasi "PSN-" jadi nanti hasilNya yg ada d kolom "nik" td adalah misal yg terinsert nilai 1maka "PSN-1".
TOLONG YA ABANG2 MASTER DB DISINI!!!
contoh syntax insert q :
insert into rs_karyawan (nama_kar, alamat_kar, telp_kar, jabatan_kar, tmptlhr_kar, tgllhr_kar, jnsklmn_kar, pend_kar, agama_kar, psnaktf, log_kar, date_kar) values('arie', 'balongsari', '7402234', 'ob', 'surabaya', '2010-12-11 00:00:00', 'L', 'sma', 'islam', 'y', 'system', current_timestamp)";
table q :
CREATE TABLE rs_karyawan
    nik         VARCHAR(10) not null,
    nama_kar     VARCHAR(30),
    alamat_kar    VARCHAR(100),
    telp_kar     VARCHAR(20),
    jabatan_kar     VARCHAR(30),
    tmptlhr_kar     VARCHAR(30),
    tgllhr_kar     TIMESTAMP,
    jnsklmn_kar    VARCHAR(30),
    pend_kar     VARCHAR(30),
    agama_kar     VARCHAR(30),
    psnaktf     VARCHAR(1),
    log_kar     VARCHAR(30),
    date_kar     TIMESTAMP,
    CONSTRAINT PK_rs_karyawan primary key(nik)
auto increment q buat masukin di kolom "nik" otomatis :
CREATE SEQUENCE rs_karyawan_seq;
ALTER TABLE rs_karyawan
    ALTER COLUMN nik
        SET DEFAULT NEXTVAL('rs_karyawan_seq');
hasil percobaan q n' hasilNya GAGAL (MOHON DIBENERIN YANG SALAH) :
CREATE OR REPLACE FUNCTION bef_ins_rs_kar_fun()
RETURNS TRIGGER AS
$BODY$ DECLARE
DECLARE
userids VARCHAR(10);
textadd VARCHAR(10);
BEGIN
userids := NEW.nik;
textadd := 'PSN-';
UPDATE rs_karyawan SET nik=textadd+userids WHERE nik=userids;
RETURN NEW;
END;
$BODY$ LANGUAGE plpgsql;
CREATE TRIGGER bef_ins_rs_kar_trg AFTER INSERT ON rs_karyawan
FOR EACH ROW EXECUTE PROCEDURE bef_ins_rs_kar_fun();
