Topic: no directory swap di ubuntu squid
2012/08/06 08:27:14| Local cache digest enabled; rebuild/rewrite every 3600/3600
sec
2012/08/06 08:27:14| logfileOpen: opening log /dev/null
2012/08/06 08:27:14| /cache/00: (2) No such file or directory
FATAL: Failed to verify one of the swap directories, Check cache.log
for details. Run 'squid -z' to create swap directories
if needed, or if running Squid for the first time.
Squid Cache (Version 2.7.STABLE9): Terminated abnormally.
CPU Usage: 0.012 seconds = 0.004 user + 0.008 sys
Maximum Resident Size: 14832 KB
Page faults with physical i/o: 0
ada yang tau ngga ini kenapa udah pusing dan mentok nih
ane lagi belajar bikin squid ubuntu 10.04
