Topic: [tanya] mo istall postgresql-8.3.10 ... ketinggalan apanya ya?
hallo semua kenalkan sy peng-install baru postgresql....ada masalah waktu ./configure di prompt root katanya gini:
debian:/usr/local/src/postgresql-8.3.10# ./configure
checking build system type... i686-pc-linux-gnuoldld
checking host system type... i686-pc-linux-gnuoldld
checking which template to use... linux
checking whether to build with 64-bit integer date/time support... no
checking whether NLS is wanted... no
checking for default port number... 5432
checking for gcc... no
checking for cc... no
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
trus, sy liat config.log nya .... katanya gini:
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by PostgreSQL configure 8.3.10, which was
generated by GNU Autoconf 2.59.  Invocation command line was
  $ ./configure
## Platform. ##
hostname = debian
uname -m = i686
uname -r = 2.6.26-2-686
uname -s = Linux
uname -v = #1 SMP Sun Jun 21 04:57:38 UTC 2009
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
hostinfo               = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
## Core tests. ##
configure:1414: checking build system type
configure:1432: result: i686-pc-linux-gnuoldld
configure:1440: checking host system type
configure:1454: result: i686-pc-linux-gnuoldld
configure:1464: checking which template to use
configure:1564: result: linux
configure:1706: checking whether to build with 64-bit integer date/time support
configure:1738: result: no
configure:1745: checking whether NLS is wanted
configure:1780: result: no
configure:1788: checking for default port number
configure:1818: result: 5432
configure:2160: checking for gcc
configure:2189: result: no
configure:2160: checking for cc
configure:2201: error: no acceptable C compiler found in $PATH
## Cache variables. ##
ac_cv_build=i686-pc-linux-gnuoldld
ac_cv_build_alias=i686-pc-linux-gnuoldld
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_DOCBOOKSTYLE_set=
ac_cv_env_DOCBOOKSTYLE_value=
ac_cv_env_LDFLAGS_SL_set=
ac_cv_env_LDFLAGS_SL_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=i686-pc-linux-gnuoldld
ac_cv_host_alias=i686-pc-linux-gnuoldld
## Output variables. ##
AWK=''
CC=''
CFLAGS=''
COLLATEINDEX=''
CPP=''
CPPFLAGS=''
DEFS=''
DOCBOOKSTYLE=''
DTRACE=''
DTRACEFLAGS=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
ELF_SYS=''
EXEEXT=''
FLEX=''
FLEXFLAGS=''
GCC=''
HAVE_IPV6=''
HAVE_POSIX_SIGNALS=''
INCLUDES=''
JADE=''
LD=''
LDAP_LIBS_BE=''
LDAP_LIBS_FE=''
LDFLAGS=''
LDFLAGS_SL=''
LIBOBJS=''
LIBS=''
LN_S=''
LTLIBOBJS=''
MSGFMT=''
MSGMERGE=''
NSGMLS=''
OBJEXT=''
OSSP_UUID_LIBS=''
PACKAGE_BUGREPORT='[email protected]'
PACKAGE_NAME='PostgreSQL'
PACKAGE_STRING='PostgreSQL 8.3.10'
PACKAGE_TARNAME='postgresql'
PACKAGE_VERSION='8.3.10'
PATH_SEPARATOR=':'
PERL=''
PORTNAME='linux'
PTHREAD_CC=''
PTHREAD_CFLAGS=''
PTHREAD_LIBS=''
PYTHON=''
RANLIB=''
SGMLSPL=''
SHELL='/bin/sh'
STRIP=''
STRIP_SHARED_LIB=''
STRIP_STATIC_LIB=''
TAR=''
TAS=''
TCLSH=''
TCL_CONFIG_SH=''
TCL_INCLUDE_SPEC=''
TCL_LIBS=''
TCL_LIB_FILE=''
TCL_LIB_SPEC=''
TCL_SHARED_BUILD=''
TCL_SHLIB_LD_LIBS=''
WANTED_LANGUAGES=''
XGETTEXT=''
XML2_CONFIG=''
YACC=''
YFLAGS=''
ac_ct_CC=''
ac_ct_RANLIB=''
ac_ct_STRIP=''
acx_pthread_config=''
autodepend=''
bindir='${exec_prefix}/bin'
build='i686-pc-linux-gnuoldld'
build_alias=''
build_cpu='i686'
build_os='linux-gnuoldld'
build_vendor='pc'
configure_args=''
datadir='${prefix}/share'
default_port='5432'
docdir='${prefix}/doc'
enable_debug='no'
enable_dtrace='no'
enable_nls='no'
enable_profiling='no'
enable_rpath='yes'
enable_shared='yes'
enable_thread_safety=''
exec_prefix='NONE'
have_docbook=''
host='i686-pc-linux-gnuoldld'
host_alias=''
host_cpu='i686'
host_os='linux-gnuoldld'
host_vendor='pc'
includedir='${prefix}/include'
infodir='${prefix}/info'
krb_srvtab=''
ld_R_works=''
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir=''
localstatedir='${prefix}/var'
mandir='${prefix}/man'
oldincludedir='/usr/include'
perl_archlibexp=''
perl_embed_ldflags=''
perl_privlibexp=''
perl_useshrplib=''
prefix='NONE'
program_transform_name='s,x,x,'
python_additional_libs=''
python_configdir=''
python_includespec=''
python_libdir=''
python_libspec=''
python_version=''
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
vpath_build=''
with_bonjour=''
with_gnu_ld=''
with_gssapi=''
with_krb5=''
with_ldap=''
with_libxml=''
with_libxslt=''
with_openssl=''
with_ossp_uuid=''
with_pam=''
with_perl=''
with_python=''
with_system_tzdata=''
with_tcl=''
with_zlib=''
## confdefs.h. ##
#define DEF_PGPORT 5432
#define DEF_PGPORT_STR "5432"
#define PACKAGE_BUGREPORT "[email protected]"
#define PACKAGE_NAME "PostgreSQL"
#define PACKAGE_STRING "PostgreSQL 8.3.10"
#define PACKAGE_TARNAME "postgresql"
#define PACKAGE_VERSION "8.3.10"
#define PG_VERSION "8.3.10"
configure: exit 1
--------------------------- msalahnya dimana ya?
apa ini no acceptable C compiler found in $PATH...
gimana solusi dan installasinya (sy di debian GNU/Linux 5.0.2 Lenny)?
Mohon pencerahannya..
Terima kasih buat Bpk2 / Ibu2 sekalian
2
Re: [tanya] mo istall postgresql-8.3.10 ... ketinggalan apanya ya?
sepertinya sudah jelas kesalahannya: gak ada gcc
aneh juga, mungkin harus diinstal dulu di debian?
atau path-nya bukan di /usr/bin atau /usr/local/bin
